pulls to the left
manger
Placerville, CA
when I hit the brakes the truck jumps to the left. Any suggestions? I recently cleaned the left side brake rotor and pads during a steering knuckle replacement (had a wasted lower ball joint!). bearings seem tight. balljoints seem good. should I bleed the right front caliper? check the rear brakes? am I missing a something?
Pulls to the left while braking = A stuck right caliper that isn't working. Jack the truck up and see if the wheel still turns while you have someone else hold the brakes on.
