swynx
So I replaced my moms clutch ffor her. (They were gonna wing it without a torque wrench)
Her boy friend replaced the master cylinder... I put in a new slave, fly wheel, pressure plate, rear main, clutch disk... the works.
Take maybe 5 minutes to bleed it. Can drive 30-40 miles then it starts losing pressure and you have to drive it home without a clutch. Bled it 5 times. Any place I should check for a leak ?
When I bleed it I put clear hose on it. Have someone push the pedal repeatadly then hold it in and release the pressure screw. This is how the Toyota dealership and oreillys said to do it. I stop bleeding after I stop seeing air.
