prepping 98 4.0 spring engine swap
Denisefwd93
South East PA
As some know I have a 98 4.0 and M5OD for my 93. looks like I'm waiting until spring.
We will pull the plugs and get the engine set for storage. "any" kind of oil in the cylinders to prevent rust?
Good advice I've received is; replaced crank seals, pan and intake. should that wait until we are ready to do the swap?
Flywheel was near perfect but is probably already rusting.. put grease on it for now, so it doesn't get pitted from more rust? I could paint it with candle wax too I guess.
Is there ANYTHING other then the older 4.0 harness change, intake and accessories to change to go into my 93 which does NOT have an EGR? Ex manifolds look about right but not quite sure.
thanks all!
