power windows and locks from an 87 Bronco II to an 88 Ranger...
Clayton Lowrance
I read the help and instruction that you gave to another member. Is the '89 diagram for converting to power windows the same as an '88?
it is a plug and play thing on an 88. the harness for the lights is a little different but just un plugs. it is easier to do with the front fenders removed to run the wiring for the doors. the only other thing is you have to add a fuse in the fuse block. the spot is there just no fuse
