Power Upgrade... Throttle Bodies, Head, Header Swaps??
Mike Tech
I want to know it anyone makes aftermarket T.B.s for a 3.0
Ranger? Would I be able to take a T.B. off another Car/Truck.
I am lookin for a 60 or 65mm T.B., I want to put a T-Bird M90
SuperCharger on my truck. I will swap the MAFS from the
same car I pull the Blower off of, Along with the 30# Injectors.
Also are there any cars/trucks/vans that have better heads
then the Ranger 3.0 Heads? Do the Heads or T.B. from a 3.0
Windstar or the Sho Swap over n Bolt on the the Ranger Block?
Can a 2.9 or a 4.0 set of headers be MADE/FORCED to fit/work?
I wont pay $500 + for a set of headers to flow a lil better, n maybe
like 5HP n 10TRQ.
Thank You,
Mike Tech
the M90 SC blower comes with a bigger TB. As for trying to fit the M90 on your 3.0 it can be done but your talking about alot of fabrication involved you may want to start searching. And NO the headers will not fit look for headers for the 3.0
if you want a 60MM TB your only option is to adapt an escape 3.0 TB. it requires a little bit of JB weld filler to make it seal, but it works.
there are no direct replacement aftermarket TB's that large.
no other heads will bolt to your engine. the 3.0 is alone in its engine family...since its isnt related to any other ford engines, very few parts will directly interchange.
the only headers that will fit are 3.0 headers.
i dont think any SHO parts will interchange, the 3.0s in them were yamaha DOHCs i believe.
