power steering leak. still
spdcrazy
Homer, alaska
mostly 86
ok so last week i blew the pressure hose on my 2.9 b2. so i replaced it with a new one from autozone. now the damn thing leaks bad. and the leak isn't coming through either set of threads, its coming from the seal thats created when you tighten the small 5/8 nut on the pump. or i think so anyways, the fluid is coming from the outside of the line itself. between it and the 5/8 nut.
everything was clean before install. and i tightened everything down pretty tight, i would be concerned bout tightening it more....
someone stole the o ring off of it. hense the leak. problem solved!
