Power and MPG?
F84R
Washington
Has anyone done a duraspark conversion with a fuel injection swap on a 2.8? the reason im asking is cuz I wanna know is i want to know if it will increase power and mileage. these two seem to be the most popular mods and I was wondering if i could combine the two.
I have a 1984 Ranger base model 2.8 reman 2150carb, 5 speed 151,000mi. I am going to do the FI swap for sure. would it be better to use an MSD ignition unit instead? What will give the best combination of power and mileage?
An EFI system would probably loose MPG on the 2.8. It depends on how the system is set up. There is no possible way that you would gain both power and mileage. That has been proven. You would gain driveability, no doubt about that.
MSD uses a Duraspark pick up, And costs a bunch more. The only real benefit is the roller bearings instead of the bronze bushings. An MSD box (offroad 6) would be better than a duraspark box.
The factory systems use a hall effect dist like a Mallory unilte. The first thing you need to do is find a F.I. system that will work on a 2.8 and see what kind of ignition they recommend.
OR, You could upgrade to a 4.0 with all its wiring and fuel system.
you have same setup i have,right down to mileage.i believe there is a writeup in tech library on 3.8 fuel "infection" swap,they say it is pretty easy.i'm going duraspark-holley myself,don't care what others say,i like my carbs.good luck.
well, no necessarily. increasing efficiency could technically provide an improvement in power and economy...and fuel injection is definitely more efficient than carburation.
does the improvement warrant the hassle of a F.I. swap? probably not. for about the same amount of work, a guy could swap in a 2.9, 3.0, or 4.0.
If I could get my hands on a 4.0 V6 low mileage and tranny with it for less than 400 i would in a heartbeat but I cant afford it as I am a student with loans and stuff. these mods are something I could do in a weekend or on a break. I am only getting about 16 to 17 mpg and I drive 40+ miles a day. I need better mileage and I cant afford anything else. buy this stuff piece by piece and wait until I can do it.
How difficult is it to remove the wiring harness through the firewall? Also, Is there a main wiring connector into the computer or is it built in?
In my humble opinion you are wasting time and money trying to put this much time and money in a truck that is 23 years old with 151,000 miles on the engine. I understand being a student, and being poor, but you would be better off putting the $500 tword a solid used car, ie vw, civic, saturn, mazada all four I have worked on and had well over 200,000 miles and still getting ~30mpg, and probably smoke your ranger off the line, cause they smoke mine. The 2.8l engine is a great small truck engine with a lot of torque for it size! I get ~19 mph on the highway, with 33 and 4.10, and no overdrive, but its no econo 1.8l. Just my two cents before you spend all your money for a FI set up, just to get an extra 1-2 mpg.
