Possible Timing Chain Gasket Leak?
mrhank
If all else fails, get a bigger hammer.
Hey everyone, I noticed that I may be developing a timing gasket leak. I was hoping it would be the water pump, but all the edges I can see around the pump it does not appear to be leaking... I drove the truck for a good hour yesterday came home and parked it and noticed a small puddle of water under the drivers side of the motor.
Was not able to check it our right then and there but looked under this morning and saw some antifreeze residue on the front left of the oil pan. You can see the leak here in the pic. If it is the timing cover that is leaking I probably will just replace the pump anyways as I will already be there. Just wanted a couple second opinions before I order everything from rockauto.
