Popping noise
Jim Dodd
Replaced everything in the front end new upper and lower ball joints and control arms new axles new hubs and bearing but still have a popping noise in front end don't have any idea what it is or where it's coming from any help please
need more information my crystal ball is on the fritz..... when does it pop? more info on truck would also be nice otherwise all we can do is guess..:icon_confused:
inner or outer tie rod ends.
Check everything out. Especially if it wasn't knocking before you replaced stuff. If ball joints came with ny-lok nuts, not castle nut and a cotter pin. The Ny-loks need substantial torque to tighten. If a ball joint wasn't pressed into its socket hard enough to over come the nut tightening , then it is loose and would definitely knock. AMHIK :D
