sarcastic_cook
- May 4, 2013
- Manual
I have a 2002 Mazda B2300 Duratec w/5spd. I have been fighting this issue for a while. It started out of nowhere. When driving on the freeway with the temp at normal it starts to fluctuate erratically. The needle will jump from normal to the "C" (the line below the normal bracket sweep) then creep back up to normal or a little above. It will set there for a few seconds before it starts again. It will do that over and over. If I keep the engine under a load for a period of time the needle will spike from normal straight to the "H" (line above normal bracket sweep) and turn on the check gauge light. When that happens I just keep going and after a moment the needle will do a full sweep to "C" followed by it creeping back up to normal.
Everything else works like it should and the coolant is clean. The engine engine does not actually get hot.
Things I have done since this started: changed water pump, temp sensor on back of head, thermostat assy, new coolant and checked for blown head gasket with combustion leak detector.
After doing all that I still have the same issue but the needle is not as erratic as before. I am baffled by this and not sure which direction to go in next.
Thanks in advance for your help
