Norseranger
Greetings from Norway!
I have a question about some play at the C-clip end, on the rear axle.
I had my car at inspection, and I got a remark on play in the rear wheel bearings, right side. The thing is that the bearings are almost new on both sides - they probably only have a few hundred miles on them in the past 2 years. To my understanding, a little bit of play in and out is fine, but it seems there is some play both up and down, and side to side at the C-clip end, which you can feel when you push and pull the wheel, and I imagine this is what the inspector was attributing to the wheel bearings. There is no play on the wheel bearing end itself (up and down, side to side), and there is no noise from them on either side.
I have linked a video to explain the movement; basically there is up and down movement at the C-clip end, when you push at 6 and pull at 12 at the wheel, and vice versa, and side to side movement when push/pullling at 3 and 9.
www.dropbox.com
Is this normal play? If not, is this because of the supposedly bad wheel bearings, or is it significant wear in the differential? I do not have lot of experience with this, and english is not my native language, so I apologize if my question is not clear enough.
This is an 87' Ranger 2.9 V6 with 4WD, and a 7.5" Differential.
Thanks in advance,
Thor
Dropbox
Thanks in advance,
Thor
