Just finished changing head gaskets on a 97 ranger, 3.0 auto, 2wd. When it started up, it was making a loud pinging noise from engine. Sounds like metal on metal, no rhythm to it though, very random. Ran out of daylight before i could look and see if i missed something like a sensor plug or vacuum line. Any help would be greatly appreciated. Just pulled valve cover on side making noise, 2 rocker arms are a little loose with the studs tightened. I think its the exhaust on cylinder 4 and intake on 5, they are side by side. Is it normal for then to be loose??
