Any PCV(positive crankcase ventilation) system is to prevent air pollution.
Closed is just better at it than open.
PCV Valve air is allowed for in the base 14:1 fuel calculations, yes, based on engine RPMs and throttle position, its air volume is added to MAF data air volume.
Fuel trims are done from O2 sensor data.
And with a MAF system even with a vacuum leak engine doesn't run Lean, or with a leaky injector it doesn't run rich.
Unless there is an extreme leak for either, lol.
The CEL coming on and a Lean or a Rich code means the computer is still running the engine according to O2 sensor feedback, but the fuel trims are either too high or too low based on MAF sensor data and the base 14:1 air:fuel calculations the computer is doing on the fly.
On the fly the 14:1 fuel trim is 0, -1 trim mean computer is adding less fuel than calculated because O2 sensor shows a little less oxygen in the exhaust, +1 trim means computer is adding more fuel because O2 is showing more oxygen in exhaust.
It is different on many systems but -10 to +10 is normal range for fuel trims.
-20 and +20 fuel trims are when computer will turn on the CEL to notify driver there is a problem, a code like P0171 means lean on bank 1, but engine is not actually running lean, computer is adding the extra fuel to keep the oxygen level in the exhaust where O2 data says it should be, the code means the base 0 fuel trim calculation is wrong, computer is having to add too much fuel to the air volume the MAF sensor says is there.
A leak in the PCV Valve hose can cause this code, but a vacuum leak is not the only reason for this code.
Low fuel pressure means the computer has to open the fuel injectors longer than it should need to, so +20 fuel trim
-1 means injector is open less time, +1 means it is open a longer time, injector pulse width or dwell time, is the fuel trim.
O2 sensor data along with computer keeps exhaust oxygen levels where they should be, regardless of vacuum leaks, low fuel pressure or PCV Valve failure, but only as long as O2 sensor is working right, lol.
