JonnyHightower
- Feb 8, 2016
- Manual
I have a CEL P0171, lean engine condition in a 2000 Ranger, 2WD, 2.5L, manual, with 80K miles. I've noticed a low rough idle, especially just after I depress the clutch and take it out of gear into neutral. Doesn't stall, and the idle recovers pretty quickly.
I REPLACED: spark plugs and wires, PCV valve, upstream O2 sensor, MAF sensor ($$dealer$$), fuel filter, air filter, and gas cap. I ran several Techron bottles through the engine, SeaFoam'd it (top end, intake clean), and have been running plus gasoline for awhile. I tried to test the EGR by covering the EVR solenoid hole during idle (to establish vacuum). The engine nearly stalled, which suggests a functioning EGR (according to YouTube).
SPEAKING TO VACUUM LEAKS: I ran some propane along the vacuum lines with engine on and didn't hear any change in idle. A homemade smoke machine produced a little bit of smoke from the IAC valve. Normal?
SPEAKING TO FUEL PRESSURE: I measured fuel pressure on the rail. Key on engine off pressure measured within spec. Fuel pressure increased ~5 psi (to 68 psi) when I turned on the engine. Chilton predicted a drop in pressure when starting the engine. I don't know the significance of that yet. Chilton suggests using a handheld vacuum pump to further investigate, but I haven't reached that yet.
SPEAKING TO READINESS TESTING: Scanner picked up a failure: "delta pressure for downstream DPFE hose test." Might be causing my CEL? Is there a quick test I can use to test the function of the DPFE itself?
Taking the above into account, does anything stand out as a possible cause? Suggestions? Quick tests that I can do to narrow it down?
