Mike828
So I've got a 2000 Ranger with a 4.0 and when I went to work a freeze plug blew out and it overheated. Got it towed home expecting the worst so I put in a rubber plug, filled with water and it fired up and ran fine idling for about about 30 minutes. Had some bubbles in the reservoir that went away eventually so I figured maybe I got lucky.
Replaced the rubber plug with a real freeze plug and let the sealant dry 24 hours. Changed the oil and filter then put antifreeze in it and it wouldn't start. I pulled a spark plug and it was dripping gas so I pulled all of them, blew them off, reinstalled and it fired right up.
After it sat for awhile I couldn't get it to start again. I started thinking maybe coolant is getting into 1 or more cylinders and causing the starting problem so I removed all plugs and turned it over thinking it might shoot coolant out of the spark plugs holes, nothing. Replaced plugs and got it running and left the radiator cap off, it's puking coolant out of the radiator. Obvious sign of a head gasket/head issue. So I started testing to see if I could figure out if it was one head or both and I'm not getting any results that tell me much.
I tried pulling the wires on one side to see if it pressurized the cooling system, it did for both sides.
Did a compression test, 125 psi all around.
No white smoke.
No contamination in oil or coolant.
No evidence of coolant on any plugs.
I got a combustion leak detector but couldn't get a good result I don't think because I could only pump the bulb for maybe 30 seconds before coolant got pushed up into the tester, I did leave the level low in the radiator. But never saw the test liquid turn yellow.
Leak down test showed about 15% leak down all around and never pressurized the cooling system
I have found that the engine will start right up if the cooling system is empty, obviously I shut it right back off.
When I do get the engine running it runs great, I've test driven it and it seems fine. This is a work truck with 215,xxx miles so engine isn't worth tearing into to me.
Anybody got any ideas? I know the puking coolant system screams head gasket or cracked head but no tests are helping prove it to me so could there be any other causes for this mess?
Thanks for any ideas...
No white smoke.
