abillerbeck
So I have 2002 Ranger XLT Supercab 4x4 with the 8.8" 4.10 non L/S rear axle (code 97) with 212,000 miles on it. The pinion seal was leaking and I replaced it in a hurry right before a 500 mile road trip. In my haste to replace it I was running the pinion nut back on with the rattle gun with the intent to stop and use a ratchet before I ran it all the way on.... well I didn't stop fast enough. I back the nut off a bit and finished buttoning it up anyways, took it for a test drive and seem to do fine. By the end of the trip it was obvious that something was tight in the rear end... harder to accelerate.
The question is... how much damage have I done? I've asked a few shops around me about rebuilds and they all want $1,000+. I really don't want to spend that kind of money on the truck because of it's age, I'm also not sure how much longer the trans is gonna hang in there. I'm thinking a junkyard or ebay axle may be a better deal. Found some for $400 with relatively low mileage (less than 120k). Will a R7 axle code with the L/S be a direct swap into my truck?
Any other options/suggestions I should consider?
