- Jan 18, 2008
I am ready to have the system evacuated, come homw and pump the system down. I have looked for a better pump that I currently have (a venturi..I know I know). What I planned on doing was pump for about 10min, close the gauges, turn off the compressor for 10min, then pump for 10 and so on, just to give my compressor a break. HOw well do these venturi pump? Will it take like a half hour, 15 min or what to pump (or under normal circumstances)?
The reason I am doing this is because I think there might still be air in the system. Won't drop below 62Deg when on max and high and driving at highway speeds. I drained some R-134 out and it stopped overheating the engine, just seems to be stealing a little more power from the engine now than it should. Example: I'm taking off from a red light, as soon as I push the clutch in front end rapidly drops (like speed shifting) and when I shift and let up on the clutch feels like slight pressure on the brakes pulling the truck down until I throttle (this is just a very brief moment of time). If I let off the throttle the trucks slows down rapidly like slight pressure on the brakes. Does not do any of this if the A/C is off. I figured I would start with square one, since I do not know what the P.O. did when he converted to R-134 from R-12.
Thanks, I hope this is clear, I seem to have a problem writing what I mean sometimes.
-=Reno=-
-=Reno=-
