pureroundcircle
- May 15, 2010
- Automatic
Yeah i'd looked up a picture of it as well but thought maybe it looked a little different for later years, I just don't have that anywhere under my hood. I've looked all over it just isn't there, unless its hidden under the fender well or tucked deep under the headlight area or something.
I have a single wire to ground connector that I figured out must have something to do with abs, as when I unplugged it the ABS light came on, oops. I also have a 2 pin connector that hangs from the brake proportioner wiring, it is not the same as that one pictured but seems similar given that it is 2 wires with a plug on the end. The plug doesn't bridge the pins, its just a cover. I tried bridging the pins and didn't seem to run any different. I had a timing light on it and when I first started the engine it was around 10*btdc, but after warming up it appeared to adjust itself in such a way that I could no longer see the mark with my timing light. Bridging the pins had no effect.
I drove it with a loose gas cap today and it ran like a champ. I guess this weekend I'll have to see If i can figure out some way to test the gas cap, and charcoal canister valves.
I have a membership to alldatapro and their test procedure was pretty useless, generally alldata is aimed at independent shops so their tests don't require dealer only tools. But their test procedure for the evap system involves the Ford NGS tester, and a pressurized smoke machine... UGH
Paul
Paul
