holyford86
Some guy with a problem
- Aug 6, 2007
- Age
- 39
- Plattsburgh
- State - Country
- NY - USA
- many
- Manual
- Total Lift
- 7
- Tire Size
- 33x12.50R15
Truck is a 98 with a 2.5 and manual trans. I've been having an occasional issue with low idle (350rpm) and sometimes is accompanied by a stall, seems most prevalent when electrical loads are high (headlights and blower on) I can't force it to do it, it seems to just do it when it wants to, there are no codes and idle is maintained 99 percent of the time. Truck has a hair over 100k miles, tune up stuff was done when I bought it 50k miles ago and used all Motorcraft parts. Voltage stays consistent and truck has 130 amp alternator on it because it's what I had when the bearings failed on the old unit. I don't feel the IAC is bad because swapping to a known good unit didn't change a thing.
Sometimes I get what feels like a short duration loss of spark but I'm not sure if it is related to the idle issue or not, seems more prevalent when it's cooler and damp. Is this a sign of a failing crank position sensor in these? I've always worked under an assumption that they either work or they don't and there is no in between. I can hook a scope up to it and see if the crank sensor drops out or watch live data to see, but I was curious if either of these are a pattern failure on these before I go to the trouble.
