cp2295
- Jul 25, 2013
- Washougal, wa
- My credo
- If you ain't first you're last
So I have a 98 4.0, manual tranny. I had to do some wiring work and so I took the whole harness out and used heat shrink butt connectors because before I used wire nuts and electrical tape (not too professional). I know I must of crossed a wire or something because when I turn the key to start it the motor free spins, I looked at the flywheel while someone cranked the starter and the flywheel turned just fine. So I checked to see if the coil was sparking while the key was being turned and I got no spark. When I compression start it though the engine runs just fine. What could my issue be?
