Anthony2296
I got no power to the cigarette lighter socket and the fuse is go
It’s a 2004 Ford Ranger 4.0
All fuses are goodJust to confirm, Fuse #29, 20amp in the cab fuse box located in passenger side kick panel, powers both the Cigar Lighter and the OBD port
Yes. Attach the ground wire of your test light to the metal outer shell of the lighter socket and touch the probe to the center contact in the socket. If there is enough voltage, the test light should light up.All fuses are good
Is there a way to test the cigarette lighter socket wire with a test light
