New rotor is not hub-centric with OE wheel
SixFoFalcon
I did a complete front brake overhaul Friday. In addition to the pads being shot, one of the driver side caliper pins was frozen, which lead to the inner pad friction material wearing away completely and scoring the rotor. So I swapped in new rotors, wheel bearings, (reman) calipers, caliper pins, and brake pads. The brakes are great now.
Only issue is that the hub "snout" on the new rotors has a smaller outer diameter than the old ones. So there is a gap between the wheel center hole and the hub snout.
Now after all the BS I have had to go through to get the front wheels off the original rotors after they were rusted/frozen in place, I'm not exactly dying to go back to a hub-centric setup. But I'm curious if relying solely on the lug nuts & studs brings up any potential safety issues. Thoughts?
as long as youre running the standard conical lug nuts you should have no issues. ive been running non hub centric wheels for about 8 years with no issues. come to think of it i dont think my stock wheels where even hub centric.
Thanks, that's what I wanted to hear. I've driven many vehicles with the conical seat interface and not all of them had a tight fit between the hub and the wheel's center hole. The Ranger lug studs seem plenty beefy enough to handle the load, but I always worry when a replacement part has a different design than the OE stuff.
You wouldn't believe the crap it took to get the damn wheel off the hub... I'm happy to not have to go through that again. :icon_thumby:
