My french antenna should be here tomorrow but its rained all weekend and I haven't got the pole and supports anywhere near.
Just after dark Fri I decided to get a coat of paint on it due to pending rains coming so I went out and sprayed as good a coat as I could. I had already cut some rusty areas from top and bottom, and I sprayed paint also into the pipe ends top and bottom far as it would go. I looked it over this morning and it appears what coverage I got was dried before the rains..
It's a 4 pole antenna set that might reach 60 or 80 ft stretched out but I'm just going for maybe 20, which should have it above the ridge so it has a shot at all directions, no rotator, other than a pipe wrench.
I'll have 3 15ft guy wires on the bottom section and 3 33ft ones off the top, anchored into 2x6 treated wood which will be anchored where I can best get it anchored to
I'll need some more hardware tho, guy wire, cable clamps, eye bolts etc
