- Aug 31, 2010
- Oregon
- 2.9 V6
- Total Lift
- 5.5 in susp 2 in body
- Tire Size
- 35 1250
i got a 92 ranger to swap axles with...dana 35 front with 410 gears...just right for me right now even though the rear is a 7.5. the front is easy,just swap them. the rear(which i thought was going to be the easy one)it turns out, is a little narrower. i could live with this for now till i get an 8.8 exp rear down the road. the other issue is that the spring perches are a little narrower too! this add more problems to what i thought was going to be an easy swap. i need the gears...i already bought the axles. two options that i see... 1 move the spring perches in a little(this will suck since its only a little) 2 change out the carrier and pinion(did a dana 30 a long time ago), anyone have any input???
