Need some advice please
Insearch87
Hi, I have a 86 bronco 2 Eddie Bauer not sure if that even matters. Anyway I bought it after an engine swap was done and it has some querks. The main issue for now is that my turn signals only work if I turn my ignition backwards to a certain point just before it shuts off the truck. When it turns on the blinkers it also turns on the blower motor if the switches are on. What is making this happen? Is the wiring done incorrectly? Or is there something else that's causing this problem. Its very annoying having to do this Every time I get in my b2. And that sometimes it will kill the engine if I hit a hard bump in the road do to the ignition being turned so far towards the off position. Plus it doesn't always want to stay in that position and get pissed when I'm making a turn and my signals don't come on when I expect they are going to. I really don't want to get a ticket for this haha. Please help so I can save a little daily sanity. Thanks in advance
So you didn't do the swap right? You're probably gonna have to open the steering column and check to make sure the ignition switch is mounted correctly, not hitting anything or rubbing wires. Make sure the turn signal switch is tightened down too. Most problems occur from bad installation or loose wire and connections.
