fear_starts_with_FE
Ive got a 94 2wd xlt that had a 4.0 5 speed. I swapped in a 74 stock 302 and I got an M5OD tranny out of a 90 F150. I put in a new flywheel, slave cylinder and throwout bearing. I also used the hydraulic clutch line for a 90 f150 becuase my stock one broke. Everything fits in nice but the problem im having is there doesnt seem like theres enough clutch pedal. I bled the line and everything and when the engine is running its hard to get it into 1rst, 2nd, and reverse and as soon as you start letting off the clutch pedal the clutch is engaging. Is it possible the master cylinder doesnt have the volume to push the clutch in all the way? Could there still be air in the line? Can I use the 4.0 clutch line? I havnt came across any info on swapping the m5od f150 tranny into a ranger. Any help will be appreciated. Bob.
