Need Help with Positive camber 90 ranger 2WD
tomas812
Hello my fellow ranger buddy, I need you guys to bail me again. I lifted my truck and followed the instruction by ( Lifting Your Ranger On A Budget) By 4x4 Junkie
now i realize i have a positive camber. ( \--/ ) i need to correct this issue .
I spoke to Travis Gaylord at My4x4Store.com .and he suggested I install Pro Comp Camber kit 594 . Hope some one could help me out.
Thanks
Tommy:icon_bounceblue:
maybe the tie-rods are trying to hold the wheels in their original position and won't let the wheels settle into their new "tracks"....along with the need to change the camber bushings.....
need camber shim help
PHP:
:yahoo::yahoo::icon_pepsi:
ok i got a 90 ranger 2wd and i made custom 2 in lift blocke out of round stock with a 3/4 hole. then i put it all together with the stock spacer and rubber thing for the spring. i used 10 x 3/4 concrete lag bolts grade 5. heated the end with a torch and hammered them into a fat plug on the end that goes into the concrete. then ran it up from the bottom. crazy but it works. now the tow out is a bit but not bad. what shims are normally used to correct this?
is the pro comp camber part at $58 include a zero to 3 deg shim?
PHP:
Hi Doorgunner, IM lost do you maybe i should try adjusting the tie rods.
thank you tommy
