Need help with a diagnosis! Cracked head???
Little Pepe
Maryland, but my heart in in GA
I posted this in 4.0 engine forums, but didnt get a response. I was hoping someone here can help!!!
Sooooooooo, about 6 months ago I started getting a rough idle in my 1999 4.0 x cab 2 wheel drive Ranger (135,000 mi). It also began to feel like a miss throughout the RPM range. I was messing around under the hood and noticed I was low on coolant so I added some and walked back around the drivers side to goof around with plugs wires, etc. I noticed coolant seeping out of the drivers side front of the engine. Well even though Im no mechanic, I decided that was a bad thing!
My brother and I replaced the head gaskets (both sides). We took our time, did a good job of cleaning surfaces, etc. I say this so that you realize we did a pretty decent job and didn't drop beer cans down the cylinders, etc. I did however cut one important corner. This vehicle is my only car, so I checked the heads as well as I could visually (laid a straight edge against them, etc.) I did not observe any cracks, warps, etc.
We got it all buttoned up and drove away. Same missfire type condition!!!! I looked at the plugs. Drivers side front or middle plug(cant remember) looked funny(right where the head had been leaking), so I replaced it.
The truck ran like a champ!!!I was very happy. I figured the plug was just previously damaged from the leak and the replacement fixed it.
Over the next month it started showing the same condition little by little, grrrrrrrr! I have a very short commute and don't drive it a lot. Check Engine light comes on. Its an o2 sensor. Downstream and yes on the drivers side. I replace it, and it runs normal. I pass my communist emissions test and over the next few weeks the miss fire/ rough idle comes back. I should also mention that every time it shows up, its much worse when the engine is cold, as it warms it smooths out but not completely.
Today I pull out all of the plugs. Passenger side look normal. All three drivers side are very clean and have a reddish hue of light rust on the treads. Especially toward the electrode end. Im starting to think the is a cracked head on the drivers side ( the side of the original leak).
I then checked the compression to see if it was lower on the drivers side. From the fire wall forward the drivers side showed 120, 130, 120. From the firewall forward the passenger side showed 150, 140, 140.
All this confirms to me that its probably a cracked head. The problem is I really dont know much about cars, diagnosis, etc. I can do brakes, oil changes, etc. but my skills are limited.
Am I barking up the right tree here?????? HELP!!!
Is there any other test I can do???
I dont want to spent two days replacing a head and not fix it!!
Thank you in advance for your help
Aaron
From what you've said it sounds like you already have your answer. Especially with the gasket replacement and all the tests you've done.
Sent from my MB860 using Tapatalk 2
another thought,
you might have another blown head gasket.
the easiest way to check is to tear it down again and have the heads magnafluxed. if they have cracks, put a new head(s) on and call it good.
If they do not have cracks, put another 4.0 in.
AJ
Wouldnt a crack tend to be in one cylinder? My last bit of head work was Honda DOHC 16 valve in a CRV. It was a low ball fix just to replace 2 burnt exhaust valves. The engine had never been overheated. I backed off the head in 3 stages and straight edged with a level and a set of feeler gauges. It was fine, so I just lapped in the new #4 exhaust valves and put it back together. Anyway, back on point. The middle cylinder is decent. I think the head bolts at both ends werent torqued enough, or the head is warped. Not a Ford V6 expert by any means. Just throwing it out there. Pressure testing the cooling system may reveal more ideas. I've never done one , but a leak down test may help. Do you know if the engine ever over heated?
Pressure testing the cooling system? Yea, I could see how that may reveal something. Im pretty sure I got the head torqued down correctly. I followed the Manual and used new torque to spec bolts. Im about 95 % sure I didnt overheat it. I never let it get low on coolant or had a problem with the cooling system. I seriously thought about just putting a rebuilt engine in it the other day. Any thoughts on who to buy from? It seems that they start around 1500 dollars. This would address the head, gasket and block! It has 135000 miles on it, but I have treated it well. I hate to spend the $, but this will be my second time taking it down to the block, and this aint cheap either!!
Aaron
