Oh crap!
You know you have second guessed me before about 10lbs of compression in my one cylinder how you swore you have never seen and couldn't believe it. It end up to be my exhaust valve was out of round not holding any compression. That I even showed you a picture of it I might add. In that case I have seen over a dozen dead cylinders with 20 or less lbs of compression but yet you claim to have never heard of it. Also I have seen a few of your comments on here and I have to say that you do indeed steer people in the wrong direction sometimes and you seem to be very arogant with your posts. I do this everyday and have been for over 15 years now. Most of this stuff I have personally seen and others very reputable mechanics have shared there experience with me. For example... customer comes in with a rough running engine, we find that it stalls badly when the oil cap is taken off. I do a compression test and find the #2 cylinder to be around 85 lbs. Now that is getting low but should still run the car at a better level. The other cylinders are all around 110lbs so I think to myself what if I remove the oil cap and do the test over. Sure enough that #2 cylinder drops to 45lbs. Find it to be a warped head, replace head problem fixed= happy customer. So why could the same not happen with a head gasket, you act as if you have never seen it, it doesn't happen. Believe me stranger things in the car world happen. So get off your high horse and get some facts before you start yapping on this forum giving people bad advice.
Now I've went and spilled my coffee on the damn keyboard.. Your posts are humorus to say the least.
You wrote: Sure enough that #2 cylinder drops to 45lbs. Find it to be a warped head, replace head problem fixed= happy customer.
And I'm still laughing! I just didn't wish to tell you at the time it simply don't happen! But now you have went and posted crap again so I'm calling you out.
You haven't elaborated about "If you bust through the gasket on the internal engine side in the right place you can create extra vacuum inside your motor if the rest of your engine is sealed tight."
and cannot...for sure! And now you bring the "warped head" back into the mix. At the time I didn't call you out but you have went too far this time.
Just so you will KNOW! If vac can escape the head or the gasket so does COMPRESSION.. the compression causes far more problems than any vac does from the same problem.
You obviously don't have a clue about the workings of an internal combustion engine. Try not to give advice unless you have seen a post from someone else that knows something and has posted so you can copy and paste the answer.
You know owch83 this isn't a chat site where one tries to impress the girls! Dudes come on here with real problems.. Problems they have no idea how to solve. When others give answers that are impossible to CURE their problems bad things just pile up for the dudes..
It's a good thing that you would like to help! But try to limit your help to problems that you at least have some idea about.
Big Jim
