I've decided to paint the ranger.
First step will be grind off all rust.
2. Fill and rough sand all previous rust areas and dents.
3. Sand all filled areas and the rest of the paint up to 220 grit.
4. Spray with high build sandable primer.
5. Sand primer coat up to 1000 grit
6. Spray with Army Vehicle flat Olive Drab paint. (cheap, durable as heck, and I like the color)
Now this is where I need help. I want a glossy finish, which the army jeep paint won't deliver by itself. So I need a gloss clear coat. The army jeep paint is a flat enamel. What product would you professionals recomend to use as a clear coat? I don't want to use anything too expensive if I don't have to.
