NEED HELP BAD!!! engine wont turn over
guitarman124
my clutch was going out of the truck so i replaced it ... put it all back together and slave cylinder went bad but the truck did start at that time .... replaced the slave and throwout bearing put it all back together now the engine wont turn over at all ...like the clutch isnt pressed in .... what could the problem be guys
Did you plug the neutral safety switch in on the tranny maybe a bad switch or connector
yea we have checked to make sure the two wiring harnesses on the transmission are plugged in several times
But is the switch working correct dont it have to be in neutral for the starter to enguage I dont have a schematic for your truck. Have you tried a remote switch for the solenoid or a jumper wire to the solenoid make sure it is neutral to remote start it.
