My 92 ranger die on me after I pumped had and since then it started stalling on me...first it looked as it would only do it after I drove for awahile, once it was cool down enough it started fine...but then the issue became more often....repace ignition module..ran good for one day and when back to the same...I cleaned the MAF sensor, cleaned the IAC, replace the TPS and nothing...noticed I wasn't getting enough spark so I replace plugs, wires, cap and rotor and still not enough spark and replace the distributor...after all the truck didn't want to start ...one thing I noticed is while adjusting the distributor I left the key on and I keep hearing the fuel pump and the fuel fues trigger every time I turn the distributor to the right or lil bit to left...is it supposed to that.?? I set the distributor were I could hear the pump turn on and truck starts..but still stalling and dies...pls help is my work truck..
