about a month or two ago i got a set of 4" lift leafs from superlift, i was planning on eventually installing a 4" sus. but due to expences ive decided to go with the 4" SL leafs in the back with no block to acheve 2" lift in the back, and i want to install f150 coils and f150 factory spacers to gain around 2" in the front, the truck is a ranger STX extended cab with a 3.0 v6
so my questions are....
will i be able to realign the front using stock bushings?
will i have to relocate brake lines?
longer shocks completely nesscary for only 2" lift?
i reviewed the tech. article on the f150 coil upgrade and the guy claims it might be possible to realign with 3 deg. bushings, and if memory recalls 3 deg. bushings are the aftermarket ones for lifts 4"+ of lift. correct me if im wrong, it has been a while, well anyway thanks allot!
