Demersus
- Feb 13, 2011
- 2.9 V6
- Automatic
Hi everyone,
I bought my first Ranger recently, a 1990 Super Cab Custom 2WD with 2.9 V6 and A4LD tranny. My mechanic is doing a complete rebuild on the original motor, but the transmission was also having some issues; wouldn't go into gear right away and was slipping. We pulled the pan today and there is too much clutch plate material in the pan for him to feel comfortable using it. Since the engine is out, we're planning to swap it also. We're going to try to find a good junk yard unit, but I have some cross-application questions.
I did some reading about the A4LD and saw that it was used in the Mazda B-series from 1994 to 2002, but only from 1985 to 1994 in the Ranger. Can you put a Mazda A4LD into a Ranger? Did the Mazda unit have different shifting controls, cooling line fittings or other stuff like that? I'd like to put as new of a tranny in as possible, so if a Mazda unit will work that would be great. It was also used in the Aerostart until 1995, so would that work as long as it's not AWD?
Thanks,
Demersus
Thanks,
Demersus
