need a lil help
  • Thread starter Thread starter all4mud
  • Start date Start date
all4mud
Guest
After takign my 94 ranger to wellsville and seeing what it can do im gonna keep it and lift it ...... i dont liek the push botton 4x4 it sucks and takes for ever to ingage and shit .... i was looking to put a manul t case in .. i have a 88 bronco 2 with a 2.9 in it its got a manul t case with shiter on the floor and its also got push botton 4x4 on the dash would this work ..... in swaping them out my 94 ranger has a 4.0 in it .. im looking to gettn rid of the auto and running a 5 speed
your bronco has a manual shift t-case with push button 4x4 on the dash?
not sure what your trying to get at here....but either way, the case will swap over, but depending on transmissions, you may have to change the length of your front driveline.
The shift linkage may not work depending on the trans configuration as well. From my endeavors, I have come across three different shift linkages, but have had to modify them to fit when swapping cases or transmissions if I didn't have the proper linkage.
