NE1 running gt40P's with Probe Pistons?
Angie
Vancouver area BC Canada
92 & 83 project
Not sure if this is right place for this topic.....
Building up a 69 block 302. std. with a set of GT40P, Probe F2305P pistons. (good deal on CL new in box $100.00) thinking they will be running about 9:1 compression. Which is ok for emissions and regular fuel. standard rods, and 69 crank. I have 2 blocks, and the second one has the twin sump oil pan.
My question is, what style duration of cam are you/ have you / would you run with this set up?
I will using one of the 2 cams and getting it reground along with the lifters.
thanks for any advise you have, or comments.
