mrchaotica
The other day when I went to start my truck, I felt (and heard) something break inside the ignition as I turned the key. The truck started and ran, but when I went to turn it off I discovered the lock turned freely between "run" and "off" (there was no longer any detent for "accessory") and the truck would not turn off. I had to intentionally stall it to kill the engine, and disconnect the battery to keep the electrical system from draining it.
The problem is NOT the lock cylinder, nor is it the electrical ignition switch. Rather, the problem is the mechanical part that the protruding part of the lock cylinder fits into.
1. What is that part called?
2. How do I fix it?
3. In the interim, is there a wire I can disconnect (more easily than the battery cable) to shut off the truck's electrical system?
Thanks for your help!
2. How do I fix it?
