Gary101386
I go out this morning to my truck and it cranks and cranks and cranks...
Now in the past the truck has had a slight miss and when it had heavily rained it would take SEVERAL cranks before it started. I figured it was a cracked cap or something simple... Thought i would let it ride and replace it when i did my tune up once it got a little warmer.
so i checked the basics, i could hear the fuel pump when i turned the key, pulled the air filter cover off to make sure i had an absolute clear air path. pressed the schrader valve and had good fuel pressure.
Still no start...
Went to the auto parts store and get my a cap, rotor, plugs, wires, and coil.
Installed everything, still no start...
pulled a plug wire off the cap and put a junk one on with an old spark plug and realized i was still getting no spark...
put the old coil back in and it fired right up...
So i am a little confused, was it my cap rotor wires and plugs? Because obviously I got a bad coil off the shelf...
anyways, it runs PHEW!!!
Still no start...
