motor mount Lh replacement
rangerpimpn84
castile, new york
can ne one tell me how replace my motor mount on the Lh side. ive seen a thread a long time ago but cannot find it.
as in the drivers side? believe it or not, it's easier than the passenger side...
lift/support the engine somehow, you will have to lift it a few inches later. remove the nut that is on the stud sticking through the bracket attached to the engine that's coming from the engine mount. at this pint, take the weight off of the mount with the engine hoist or whatever you're using to lift the engine. there's three bolts holding the lower bracket to the engine crossmember, remove those then lift the engine as high as you can until the bellhousing hits the body or whatever. at this point you should be able to pull out the old mount and the lower bracket it's attached to. now remove the nut from the lower engine mount stud, install the new mount onto the bracket and reassemble the engine
