bilbo
- Oct 29, 2016
- South Florida
- 2.3 (4 Cylinder)
- Total Lift
- 0
- Total Drop
- 0
My truck has an MCU and uses what appears to be Duraspark ignition and vacuum advance distributor. I'm trying to diagnose an issue where the idle speeds up after the truck warms up a bit. It behaves like a vacuum leak; I can back off the idle adjustment completely and the RPMs remain around 1000.
I've isolated the effect to a vacuum switch that connects through an orange poly hose to the vacuum port under the throttle on the carb. If I pull the hose and plug it, then apply vacuum to the switch manually, I can reliably reproduce the effect. Release the vacuum on the switch and the idle slows back down.
I'm wondering what the MCU controls in this application. I wasn't able to find any vacuum leaks, and was wondering if it's changing timing. Is the MCU capable of advancing timing with the vacuum advance distributor? Unless I'm missing something, I don't see how it could be. Is there an explanation somewhere of exactly what the MCU does, and what inputs control what outputs and when?
