Mazda B-4000 p-up
bigmo445
sunbury Pa
2000
Hi to all Mazda B 4000 p-up owners.I have a problem and I am hoping someone on here can help me out.I have a '94 Mazda B-4000 pickup with a 4.0 L engine and the previous owner was apparantly not too careful when He replaced the PCM (computer) I guess his way of fixing it was to remove the check engine light.I need the Part # for the computer for my application mine has a 5-speed standard. 4X4 Federal Calibration ,AC no cruise. I would appreciate if there is someone out there with the same equipement as mine would send me the Part # or would know of a good used PCM. My PCM that is in mine is for a '94 ranger w/automatic trans. There is approx. 20 different #'s of PCM's. Pls. let me know.
Have you called or visited a salvage yard?
Even a Ford or Mazda dealer? I would think either of those could give you the exact part number. Should be the same part, whether you have a Ranger or Mazda.
JY's typically have a locator service, searching stock in other participating yards. Call around.
Ihave the same P/U. I will try to remember to look for the PCM # and post back to you. There is a Mazda-specific yard in Marysville, WA. I believe the name is Covey's. They have a B-4000 there. It could have the module you need.
Mazda dealers can you give you the exact part number with the VIN. Your VIN will not be loaded in the Ford catalog since you vehicle was not sold under the Ford brand regardles of who built it.
