- Aug 6, 2003
- Manual
Ok, so I have a funny story. Funny for you, but not very funny for me.
So I'm driving downtown yesterday, and just as I press in the clutch, I hear a loud snap, and the clutch goes to the floor. First thing to go through my mind is the disgusting task that is bleeding this stupid system. I figured the line must have came off or something.
I look under the truck, and see no fluid. Good. Next place to check is under the dash. At first glance, I thought that the heim like plastic piece in the pushrod just came off of the pedal. Nope. The pushrod actually snapped off about 1" from where it meets the pedal. Sweet. So I ended up Vice gripping what was left of the pushrod to the side of the pedal so I could limp the damn thing home. I just shifted without the clutch, so I only had to use it a couple of times to start off.
Anyways, so I bought a new master and it came with a new pushrod. It looks like the pushrod clips into the plunger, and is sort of a ball in socket kind of setup. The new one is already apart, and so I'd like to just take out the old pushrod and swap in the new one.
The problem is that the teeth that hold the pushrod into the plunger are too hard. I'm having a difficult time getting at them in order to press them in to allow the pushrod to separate. It looks like they weren't designed to let the pushrod go once it's snapped into place.
Has anyone ran into this? I think I'm pretty much screwed and will have to fool around with this joke of a hydraulic system. Worst case, I can just swap out the whole plunger with the new one, but I'm not interested in breaking open the system unless I have to.
Suggestions?
Suggestions?
