n_bannerman
Not sure if this should be in here or steering but I am having major bump steer with a leaf spring sas. Running a rear shackle setup with rancho 44044 spring set up spring under for a few months and have been fighting to get rid of the bump steer. Also when I corner hard it feels as if the whole axle will shift side to side, but everything is solid and tight and when I turn the wheels with the truck stopped it will cause the front to flex. With all this side to side force it has caused my steering box bolts to back off. Is there anything I can do to fix the bump steer other then going to a 3 link?
Thanks in advance!
Thanks in advance!
