spdcrazy
- Mar 8, 2008
- Age
- 37
- Homer, alaska
- mostly 86
i bought a m50d tranny outta a 97 ploder. and i bolted my 1350 transfer case to it, but the first issue is that the bracket that allows the transfercase to be shifted doesn't fit. the pivot bolt works. but the bolt that keeps the bracket from wiggling, is about a 1/4 in off. i could just cut and weld on a piece of plate and drill a hole, but i was wondering why i can't find anything on this on the forums? has no one had this problem before?
also, on the toyo tranny that was behind my 2.9. the clutch line connected to the top of the tranny. my m50d connects to the side. so do i need the 4.0 clutch line? or does someone make a flexible line? whats the solution to this problem?
thanks for the help!
