m50d drive shaft issues
spdcrazy
Homer, alaska
mostly 86
ok i got the m50d tranny in my 87 b2, but the front shaft is too short and the rear is too long, by about 3 in or so. stock 7.5 rear and dana 28 up front.
anyone know if the explorer/ranger etc. shafts fit? or should i just go to my driveshaft shop and get them reworked?
The front driveshaft can come from a BII/Ranger 86-87 automatic only, OR any 88-90 with the 1350 slip yoke t/case.
Rear shaft HAS to come from a BII with either an A4LD or FM146.
If you have a choice, I would stay away from the c/v style shaft that was commonly used and either buy an aftermarket one that uses u/joints, or have a longer one shortened/balanced.
I have a CV (rapezza) style shaft mentioned above I will sell ya.
thanks but i'm looking to get her running quickly. so i'll have to hit a junk yard first.
soon the 8.8 swap and dana 35 will be in process. when it does, i'll build some beefier shafts.
thanks for the imput!
Negative. The front driveshaft can also come from a manual transmission AS LONG as the manual transmission is a FM-146.
Sounds to me like you had the FM-145 transmission in it before. They were about 1.5" shorter than the A4LD, FM-146, and M50D.
Depending on if you have a flange or u-joint cups on your transfer case, I have access to a double double cardon driveshaft that just needs to be installed. It has the cardon joint at each end. The end that goes to the transfer case is a u-joint and not a flange.
Ummm.........
engdept....did you even read my post????
It was quite specific to INCLUDE the FM146 which, was factory installed in the 88+ model years.
Anything earlier than that, only the A4LD trans would work.
ohh and i had the tk5 in before, unless the bottom pan looks the same on the tk5 and the 145?
either way, i'm going to the junk yard to check things out. hope i find something
The TK5 has a rectangular finned aluminum pan, the FM145 has a square-ish steel pan with a drain plug in the center.
Regardless...they are essentially the same length.
I doubt you will have any problems finding shafts at the j/yards. They seem to be alot more common than trying to find shafts for the FM145/TK5's (at least in my area) I can't remember when the last time I had actually seen an RBV in a scrapyard around here that had an FM145, and it's been years since I last saw a TK5.
yep, i def had the tk5. used the pics in the tech library. but either way, my junk yard had to rbv, and neither one had the tranny in it, nor do they label the shafts well enough. but luckily the local machine shop is heavy into 4x4's so i'm getting the work done there.
thanks guy, ya helped out alot, even tho im getting mine shorten/lengthened.
Yeah, it's not expensive to have an existing driveshaft shortened and balanced.
Do pay attention to driveline angles. It matters quite a lot for Bronco IIs.
i spoke with the driveshaft shop, and they said they would even cut me a deal because i know some ppl. but my slip yoke splines are almost shot, and i told them while they are at it to just put in new u joints and save me the agravation.
but then they called me back with my quote, over 400 bucks for the rear shaft and more than 250 for the front. it goes without saying, i'm not getting them done there. i'll keep looking in the junk yards
OUCH!!!!
Gold plated?????
Platinum?????
That price seems out to lunch.
I agree with MAKG....it does not cost THAT much to have a shaft shortened. If the splines are really that bad, just get another longer shaft (with a good slip yoke) and have it shortened. The front shaft should be a dime a dozen at a J/Y.
ya i'm working on it monday, they were trying to give me the shaft on those shafts. lol. i'll hit a junk yard monday
hey guys. sorry for bring up my dead thread. but the B2 tranny project came back to life.
i found a ext cab ranger with the fm146. so the front shaft should work with my B2 and m50d right? but the rear would be to long right?
the front will work, but the rear will be too long. You are correct in your assumption.
