Lefty
I've read the wonderful threads on rear axels here. Thank you!
My problem is that I have no door label and no axel code on my 3.0 Liter 2003 Ranger Edge. I want to get a 410 limited slip rear axel maybe even with larger drum brakes but I would be happy with anything limited slip at all. I don't haul heavy things, no trailers either.
Junkyards are asking me to provide certain information I do not have. If you have real world experience, you might know which of these axels would fit my truck and which would be limited slip. Here's what they offer Which ones of these axels are right?
7.5" Ring Gear, 10" Brakes, 3.73 Ratio
7.5" Ring Gear, 10" Brakes, 4.10 Ratio
7.5" Ring Gear, 9" Brakes, 3.73 Ratio
7.5" Ring Gear, 9" Brakes, 4.10 Ratio
8.8" Ring Gear, 10" Brakes, 3.55 Ratio
8.8" Ring Gear, 10" Brakes, 3.73 Ratio
8.8" Ring Gear, 10" Brakes, 4.10 Ratio, Exc. FX4; ID V305 Series
8.8" Ring Gear, 10" Brakes, 4.10 Ratio, Exc. FX4; ID V311 Series
8.8" Ring Gear, 10" Brakes, 4.10 Ratio, Exc. FX4; ID V313A
8.8" Ring Gear, 10" Brakes, 4.10 Ratio, Exc. FX4; ID V313J
8.8" Ring Gear, 10" Brakes, 4.10 Ratio, Exc. FX4; ID V313K
8.8" Ring Gear, 10" Brakes, 4.10 Ratio, Exc. FX4; ID V330 Series
8.8" Ring Gear, 10" Brakes, 4.10 Ratio, Exc. FX4; ID V333 Series
8.8" Ring Gear, 10" Brakes, 4.10 Ratio, FX4 (Locking), Level II
8.8" Ring Gear, 10" Brakes, 4.10 Ratio, FX4 (Locking), W O Level II
8.8" Ring Gear, 10" Brakes, 4.56 Ratio
8.8" Ring Gear, 9" Brakes, 3.55 Ratio
8.8" Ring Gear, 9" Brakes, 3.73 Ratio
8.8" Ring Gear, 9" Brakes, 4.10 Ratio
Which ones are limited slip? Which would be a direct bolt-on? Which is simply "plug-and-play?
If it helps the last numbers on my vin are 3pb48386
