RobinHood
l wasnt getting much traffic in the 4.o forum, so l moved this here...
Without any rhyme or reason, my truck will decide it does not want to start after being hot. Then after a minute or tow with everything turned off, it will start up with no problem. As you can imagine, this happens at the most inconvenient times.
l have done my research on the board and feel that it is exaclty what is described in this thread http://www.therangerstation.com/foru...=starter+relay
however, l cannot locate the relay. The stealership said they need the number from the part to look it up.
Is it also known as the EEC power relay in the distribution box under the hood and are all four (AC WOT, FUEL PUMP, EEC & Fog Lights) of the relays interchangeable so if l bought four new ones l would be ok?
The AC and Fog light relays have different part numbers on them when compared to the EEC and Fuel pump relays.... but when l look them up on Napa Auto Parts and Auto Zone they are all the same?
Any help would be great... thanks in advance
