Location of 2003 PCV valve
04FX4
I,m helping a friend with his 2003 FX4. We cannot find the PVC valve. Any body have a picture of this elusive part?
It will be at the back of the valve cover on the drivers side. Some of them have a coolant line that flows through them.
PCV valve
Thanks, found it. Looks a little tight to get too. Will use different fingers than mine.
If you remove three of the spark plug wires out of the coil pack, the PCV valve is fairly accessible. Unless they changed the design from 02 to 03, you have to rotated the PCV valve to get it out. I found removing the coolant hoses the biggest hassle in changing the PCV valve.
