I have a 2000 Ford Ranger 2wd. I was wonder what it would take to fit Lightning front brakes on my ranger. I was planning on my summer rims being Lightning wheels. Could it work?
From what I can tell: F-150 spindle is MUCH larger than the Rangers, so without a bunch of custom machining, you can't put Lightening hubs on Ranger (didn't even look at how brakes lined up....).*
Which leaves you with spacers - Ranger pattern inner/F-150 pattern outer. Not sure if you want the wider track or not.
They're not even close. The F150 has a much larger spindle, and bolt pattern than the Ranger.
If you want bigger brakes, there are a few dozen guys, including myself, that run Mustang brakes. They still require a good bit of work, but the bolt pattern is the same, so it's not as difficult as converting to Lightning stuff.
If you just want lightning wheels, run adapters. If you want bigger brakes, sport trac brakes are larger and easier to fit without a lot of custom work...
For
a small yearly donation, you can support this forum and receive a 'Supporting
Member' banner, or become a 'Supporting Vendor' and promote your products here.
Click the banner to find out how.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
