LED 3rd Brake Light
Only down side is that it has the cargo lights which I do not have currently. I may wire it up to my dome light.
its plug and play my friend, no wiring needed. I had just the red one on my 95, swapped it for the one with cargo lights...worked perfect!
don't quote me lol but you should just be able to plug it in an go!
If you have 3 wires going to the light, then you're already wired up for cargo lights. If you have only 2, then you'll need to wire it yourself. My 06 was not wired for cargo lights. I mounted a toggle switch on the dash and ran the wire right to the fuse box.
I've been looking at these for awhile. Once I get the funds I want to do LED 3rd and regular tail lights for my truck. I'm a tad bit LED obsessed lol
I want LED tails as well. When I get them I am going to use a VH Nightshade on them w/ the reverse lens left alone. I have 30% tint on the back and 5% tint on the doors and extend cab windows so it is a little dark in the cab.
I have LED tails. They are just the stock housings with LED bulbs. I didnt like any of the aftermarket ones.
